5 662 läst ·
147 svar
6k läst
147 svar
Induktionshäll där 3e fasen saknas!?
ok, så om jag söker på glaskeramik får jag träff på induktion?returen skrev:
Tror inte det..
Gorenje säger så här
Differences that only truly become apparent when cooking.
Induction vs. glass-ceramic: They may look similar at first glance . But the differences are clearly noticeable both technically and in everyday use . And they also have a significant impact on your electricity bill. We'll show you the differences based on several aspects.How it works
You're certainly familiar with glass-ceramic cooktops . After all, these ceramic cooktops are now found in most kitchens. They work just like cooking on a regular cooktop: The ceramic cooktops heat up after the stove is switched on – indicated by the red rings on the cooking zones – and transfer the heat to the pots and pans placed on them. Once you've finished cooking, it takes a while for the glass-ceramic cooktops to cool down again.At first glance, induction cooktops look like glass-ceramic – but only on the surface. Beneath the glass-ceramic surface of the modern cooktop are flat coils made of copper wire. When you turn on the cooktop and place ferromagnetic cookware on it, the coils generate an electromagnetic field. This creates small electrical currents in the bottom of the pot, which then heat it up. Unlike glass-ceramic cooktops, the cooktop itself remains almost cool with induction – only the pot gets hot . You can cook and fry just as usual.
cleaning
When it comes to the tiresome issue of cleaning, induction has an advantage over glass-ceramic . Because the cooktops themselves barely heat up, it's not quite as critical if milk boils over. Unlike with ceramic cooktops, it hardly burns on. This makes induction slightly superior to glass-ceramic when it comes to cleaning.Cost
Modern induction cooktops are usually more expensive to purchase than classic ceramic cooktops. The new ferromagnetic pots and pans you will also need to buy will further increase the cost.But the more energy-efficient cooking method results in significant savings on the electricity bill. Pots and pans heat up even faster on induction cooktops than on glass-ceramic ones. Induction cooktops use between 15 and 20 percent less electricity than ceramic cooktops.
nu är gorenje kinesiskt så en del översättningsmissar blir detD Dilato skrev:ok, så om jag söker på glaskeramik får jag träff på induktion?
Tror inte det..
How it works
cleaning
Cost
annars beror det på att gorenje vänder sig till hillbillies och rednecks som omöjligen skulle förstå det jag skrev innan.
lågpresterande skulle ta för lång tid för att förstå att en glashäll är en glashäll oavsett om det ligger något under eller vad som skulle kunna vara där.
Det är ju precis lika dumt med kondenstumlare såväl eluppvärmda kondenstumlare som kompressoruppvärmda båda använder värme som kyls ner för kondensationen försök att få en från sveriges framsida att förstå detta.
Därför har branschen för att underlätta för de svagsinta valt att kalla den ena för kondenstumlare och den andra för värmepumpsdito
Tack! Lade upp fel länk.D Dilato skrev:
Svart induktionsspis:
https://www.elon.se/electrolux-excellence-xei6538ss-150586
Fairlane
· Stockholms Län
· 18 337 inlägg
Fairlane
- Stockholms Län
- 18 337 inlägg
Klart det finns kablar som tål det, men frågan är om spisen är utmärkt och kan nyttja full effekt för de som idag kör enfas, i Sverige. Det var det jag kommenterade, även om jag bara klippte ut en del, för tydlighetens skull, men det blev kanske otydligt istället.Bönhas skrev:
annars sätter man en takskenaBönhas skrev:
det är ju bara arean det hänger på
jag har mycket som sitter med 3x63A men inte f-n vill jag försöka få in det i en sketen konsumentspis
Kompisen har 63A avsäkring av sin villa. I Göteborg betalar man bara effekttariff och ingen nätavgift för säkringens storlek.Bönhas skrev:
Hobbyelektriker
· Värmland, Molkom
· 27 014 inlägg
Det måste ändå ha kostat din kompis en bra slant då servisen ska dimensioneras för 63 A.
