1 224 756 läst ·
17 459 svar
1225k läst
17,5k svar
Allt om bilen
https://www.bimmer-tech.net/blog/item/115-bmw-battery-replacement-and-registration
https://www.garaget.org/forum/viewtopic.php?id=289183
Här kan man se ett exempel också:Why is battery registration important on BMW?
The electrical system of BMW models manufactured after 2002 got very sophisticated, as it started to adjust charging to the age as well as the type of the battery. If you’re changing your BMW battery for a new one having different capacity or type, your DME has to be updated with this info. It happens for example when you’re switching between batteries with lower and higher cranking ampere ratings or swapping a Liquid Lead Acid battery for an AGM battery. However, swapping your old battery for an identical one also doesn’t free you from the obligation to go through a BMW battery reset procedure, as your vehicle has to program the battery capacity again.
What happens if you don't register BMW battery?
Registration is required so that your car knows about the changed specifications and can adjust to the new battery settings. Otherwise, if you don’t properly code BMW battery, it could result in many electrical problems; the battery life may decrease, you could overcharge or undercharge your battery, or in the worst case scenario, cause considerable damage to your vehicle’s alternator and electrical system — at this point your battery may fail prematurely.
What are the electrical errors that might occur? Certain modules of your BMW may turn off as a consequence of your car presuming that the battery life is low and wanting to save it. So, at that point your windows and mirrors may not close/open, your radio and interior lights might not work properly, or other modules not needed for starting or driving a car can fail.
Which BMW models require battery registration?
All BMW models introduced after 2002 require battery registration, as they are significantly more advanced in terms of electrical environment, which aims to improve the gas mileage. Models developed since 2002 are equipped with the system of Intelligent Battery Sensors (IBS) that contains micro processors monitoring and measuring charge, discharge, voltage, current and battery temperature.
To confirm whether your vehicle requires battery registration Contact us.
What is the cost of battery registration in car shops?
When going to the car shop to replace your old battery with a new original BMW battery, the costs may turn out to be higher than you’d expected. The registration of the battery itself costs around $200.
Jag tror ni får bestämma er för om det är batteriet i bilens fjärrkontroll (nyckel) eller bilens 12V startbatteri ni vill diskutera. Att en "modern" bil, ja typ nyare än 20 år har BMS är ju snarare en självklarhet och varenda eftermarknadsscanner kan registrera in ett nytt startbatteri.
Allvetare
· Västra Götaland
· 12 386 inlägg
Som ett skämt kan man tycka
Hobbyelektriker
· E
· 15 516 inlägg
Ett tragiskt skämt. Vad blir bättre?
Allvetare
· Västra götaland
· 10 983 inlägg
Jahapp, då gick man och blev ägare till en SAAB 9-5 -03 ... 🙄
Nån som vet om nyare "universal-scanners" klarar av att gifta radion med bilen, eller om det bara kan göras med Tech2?
Jag har flera gånger försökt hitta en detaljerad förteckning över vad olika "scanners" klarar per biltyp. Länka gärna om du har hittat något sådant för Launch och olika bilmodeller.Kuslake skrev:
I fallet Saab så kan man köpa en Tech2 från Kina eller en begagnad original som klarar allt som behövs för Saab och andra äldre bilar från GM. Då behöver man inte undra vad som klaras och inte klaras. Man kan även försöka hitta folk på t ex Saabturboclub.com som har Tech2 och kan tänka sig att hjälpa till med enklare uppgifter.
Allvetare
· Västra götaland
· 10 983 inlägg
Ja, det är nog alternativet.. det verkar som nån bytt batteri nyligen, så jag antar att det är därför den tappats.. grabben som ska köra verkar inte bry sig om radion alls... 🤯😂T TommyC skrev:Jag har flera gånger försökt hitta en detaljerad förteckning över vad olika "scanners" klarar per biltyp. Länka gärna om du har hittat något sådant för Launch och olika bilmodeller.
