250 408 läst ·
1 367 svar
250k läst
1,4k svar
Tian chen s510
Idag kom jag på klipparen med att springa runt i cirklar. EXAKT samma cirkel, varv efter varv. Efter uppemot 40 varv så ledsnade jag satte foten i vägen och då avvek den.
Men skam den som ger sig!
Jag åkte ett ärende på en timme, och när jag kom tillbaka så cirklade den runt igen, I SAMMA CIRKEL!
(Crop circles anyone???)
Har någon av er det samma snurriga beteende?
Tianchen planerar en ny uppgradering av klippare. Jag har föreslagit följande förbättringar:
1. Height adjustment: According to S510 most use 3-5 in that scale. In sweden the lawns have oft moss which is very soft, so mower works with Wheels deeper in the ground, which means it is very good to have possibility to change cutting height.
2: Ultrasonic sensors. It makes easier to draw virtual wire on the lawn, its safer for small Children and when you are working in the garden, picking fruit from trees, fertilizing, Children toys, trampolines and things like that.
But design reliable function, must work 100%
3:Bluetooth
Yes it can be future, so people not need to go to display and stop the mower
4: Better Quality in hardware e.g frontwheels, gears in driving motors,
5.Terrain rearwheels
6. More weight over rearwheels
7. Reliable within the area, if outside area, mower must stop immediately
8. When bumpy ground, today mower leaves a disturbing sound from pressure sensor nuts and washer below connecting rod when topcover moves up and down
9. When hitting an obstacle or wire from a side, mower must turn always in opposite direction
10. If mower stops of some reason, it must be possible to start again where it stands
11. Compass function must be reliable to steer mower straight on direction even in slopes and inclined lawns
12. Make it easy to make service, fewer screws, good marking of cables and connectors, easy to change cables and parts
13. Show time how long mower have left to work or how long time it has worked in display
14. Easier to make schedule, default start time (09.00) and schedule 90 min per area
15. Possibility to program 5 areas
16. Guiding wire when battery need charging
17. Better steel quality in knife
18. More reliable components and connectors generally
19. Secure if mower cross wire going backwards, so there is a sensor detecting and stopping wire crossing
20. Moderating (shock absorber) frontwheels so mower goes softer in bumpy ground
3:Bluetooth
Fastnade den på samma plats igen måste det vara något som stör den, tänkte eftersom den gör en cirkel på 1,5m kör du en äldre version av programvaran?eleson skrev:
Den nyaste "juni" har mindre känslig kompass kanske funkar.
Du har inte köpt något nytt hemma som kan störa klipparen.
/Henrik
Bingo !!!Marquiz78 skrev:
Jag har borrhål i den gräsmattan, med ett brunnslock i stål över. Ca 10-15 cm under jord.
Troligen är det i cirkeln.
PS.
Har maskinen på slaktbänken nu, senaste mjukvaran skall inopereras.
