1 479 läst ·
10 svar
1k läst
10 svar
FTX återvinningsaggregat
Hey!
I hope english works fine here? We bought a house that was built 1993 and has had the same värmeåtervinningsaggregat in the basement since then. We changed it half year ago to systemair ftx.
my question is…in winter when its around -6 outside we sat the temperatur on the little screan to 28gr and a normal flow. It seems to be working because the air in the basement is stable 20gr. But in the house it gets cold to 13gr unless we use extra element or make fire in kamin. Is that normal or are we doing something wrong?
thank you for answers,
mvh, Veronika
mvh, Veronika
If you want heat from your FTX you must activate the heater in the FTX. Se manual.
Normaly the FTX recovers the heat from your house but you are allways loosing some heat.
So you must add heat with the extra heater in the FTX. If you have a VSR 300 the heater is about 1,67kW.
