I’d pull up the plastic mat or at least lift a corner to see if moisture or old grime got trapped under it, because that can stink for years. I’ve also aired out stubborn smells by scrubbing the surfaces with vinegar water and then burning https://nothingbutscents.com/collections/sage for a bit; I’ve found the mix of cleaning and smoke helps clear out that lingering funk.
