Har ändrat planlösningen och vill flytta med en takrosett till annat rum.
Takrosetten är gjord i gips och sitter på putsat tak som i sig är gjort av vass.
Någon som har en idé om hur man kan få ner den i sin helhet?
Ok att skada taket.
Are you sure it's plaster? I once came across a rosette made of... lead. Seriously. Heavy as hell. But this one looked suspicious right away because of the very thin flower petals that couldn't be made of plaster. It turned out it was screwed to the ceiling. You should support the rosette from below, then use a guitar string (with a braid) to cut it off
