First of all sorry about using English in this forum as I am not very good with Swedish yet, I have recently moved into a villa and came across a very annoying problem last night as I couldn't sleep due to the noise of raindrops hitting the aluminum sill at the window of my Bed room and the balcony area.
Please suggest Is there something that could be done to fix this issue
Translated using Google Translator:
Jag har nyligen flyttat in i en villa och stötte på ett mycket irriterande problem igår kväll eftersom jag inte kunde sova på grund av bullret från regndroppar som slog på aluminiumfönstret vid fönstret i mitt sovrum och balkongområdet.
Vänligen föreslå Finns det något som kan göras för att åtgärda problemet
Kan själv!
· Trelleborg
· 20 045 inlägg
If you can remove the sill, I would try adding a bitumen sound proofing mat on the underside.
https://www.biltema.se/bil---mc/biltillbehor/ljudisolering/ljuddampningsplatta-2000018990
Kan själv!
· Trelleborg
· 20 045 inlägg
I would stick it on the underside, the side you normally dont see.
Kan själv!
· Trelleborg
· 20 045 inlägg
What I mean is that you stick it on the side of the sill that you cannot see.
We have a similar mat in the underside of our kitchen sink to reduce sound.
Husägare
· Klagshamn
· 285 inlägg
I think the metal acts like a drum skin now, it's thin and quite flexible. If you manage to get some sound deadening, like the suggested bitumen mat glued to the underside of the metal plate it would reduce the sound. The basic idea is to transform it from a thin flexible metal piece to something more rigid with more mass that can't vibrate as easily.
Aha, that makes perfect sense to me now, thanks @Keld and @Snappahaneklanen for the detailed explanation
I just gave it a closer look and it seems sills are fitted with nails and not the screws so it's not something I could open up easily.
Is there any other workaround that you could think of, I was thinking about putting some waterproof tape, it could be silicon tape or foam tape or something similar that could fix this issue either way or other, However, I also don't want to spoil the look of my balcony or the window.
I had the same issue and actually came across this thread a couple of years ago while searching for a solution.
I was sorting my bookmarks, and I just remembered it now, so I thought I’d share some info.
If your issue is still relevant, I found a solution from blobbplopp, a Germany-based company that focuses exactly on this problem. They offer several ways to deal with rain noise / drops hitting the window sill.
In my case “Fensterwiese” worked just fine. (roughly "window-meadow").
I’m not sure about different window/sill constructions, but I think they can give better advice if you reach out to them by email.
Lycka till!
Lycka till!
I just glued bitumen mat on the upper side it was visible and ugly but less noiseR ripz_gul skrev:Aha, that makes perfect sense to me now, thanks @Keld and @Snappahaneklanen for the detailed explanation
You can also try to push in from underside a few rubber toy balls the kids play with the balls which can bounce very high, you can cut them to size to slightly fit in but just push the metal up a bit
