Hi,
Im doing the bathroom and will put a panel shower on the wall. I will draw up 2 pipes inside the inner walls to connect to the shower to the vvs/kvs.
However when I removed the panel off the wall I found some electrical cables (in side the plastic tubings) about 30-40cm from where the water pipes will go.
I know there are a lot of regulations for inside the bathroom for EL and water, ie. IP44 etc, but is there any restriction for EL cables and water pipes that will be inside the walls?
cheers
Neil :-?
neiloc skrev:
Hi,
cheers
Neil :-?
no, it´s okej.
