I need a powerswitch which I can command over internet to switch lights and electric heaters on and off.
I found one but that one is for phoneline and the problem is that I only can connect one to the phoneline and I need more.
This is the one I found :
http://www.expressel.se/group.htm?category_id=15062
Does anyone know where I can buy one that I can connect to my router (internet) ?
Tack
Mvh
Nol
Change your router to a Dovado UMR and use Tellstick?
Thank you all for all information and advices. d^_^b
I have Telia bredband with D-Link DIR-615 router and the TP-Link TL-SF1008P switch for my 3 IP camera´s. They are connected by UTP cable and POI.
Thank´s to Mycke_nu, I search around on Google and found more information.
One that I found is this : http://www.alentis-electronics.com/NETPING 2PWR-220.html but that goes up to 500 watt and that is not enough for an electric heater, they are 2000 watt and I have 4 of these.
I wrote them a mail because they have bigger power switches too and I am waiting for there answer
@Fredl and Nerre, I look at Dovano plus Tellsick and that looks fine but I resently bought the DIR-615 and I also have to buy the receivers of the signal from the Tellsick.
I am thinking about the one from Alentis-electronics but maybe that cost much more because I need 4 big power switches and then Dovano plus Tellsick is a good solution. Thank you both
I am going to search around with all your information but if you have any advice please let me know, I appreciate it very much.
Mvh
Nol
Receivers for use with Tellstick aren't very expensive. Rusta have a set of 3 for 99 at the moment (bought them last week), Jula have a set of 3 self-learning Nexa for 199.
Use the cheapest switch that you can find. As long as it can handle 1W you can connect a relay or contactor and switch as large a load as you like.
