Hi all,
Prior to going on vacation I had the following settings on my heat pump:
- Val, värmekurva = 10
- Förskjutning, värmekurva = +1
- Elpatron ON
- Cirk.pump ON
- Extra varmvatten OFF
- All radiators set to 2 or 3 out of 5
- The pressure level oscillated between 1.3 and 1.4
I recently went on holiday and set the Nibe Fighter 310P as follows:
- Förskjutning, värmekurva = -2
- Elpatron OFF
- Cirk.pump ON
- All radiators turned OFF
- After returning from holiday the pressure level was between 1.6 and 1.7
Then I readjusted the settings to their original levels, except that the radiators are still OFF. However, the pressure level remains stable between 1.6 and 1.7 one week later.
According to the instruction manual, the normal pressure levels are from 0.5 to 1.5.
Is this something I should be concerned about? What actions would you recommend, if any?
