1 410 läst ·
2 svar
1k läst
2 svar
Help please
hey guys I hope you are doing well!
I need some help with a lighting method
so here is the case... I want to do some renovations at home so how I would like to control some of the lamps is that I want to install a normal switch or a push switch on the hall so when I get inside the house to push that switch and all of these lamps (living room and bedroom lamps) turns on,,,, then on the living room and on the bedroom I want to install dimmers so I can dim the lamps there. after that when I get to sleep and turn off the lamps by the dimmer in the bedroom and then in the morning when I go to work I will turn off the lamps with the main switch on the hall, and when I come back from work I want to turn on the lamps with the main switch, does it go and the lamps turn on even if the dimmer is in the off position on the bedroom? is there any possible way to install something so I can control the lamps this way?
I really would appreciate it if someone could tell me a method!
Thanks a lot
Agron
Thanks a lot
Agron
