Hello
I see other posts related to this but it doesn't cover what my problem is.
I live in southern Sweden and have problems with the humidity in the garage. It sometimes goes up to 90 percent. I have a garage with storage as in the picture.
In storage the humidity is below 70 percent and when I use elements it is even lower but it is the garage where I have problems with humidity.
What I tried
Dehumidifier 30 m² from Christmas but it works when the temperature is above 5 and I have to put elements that take some time to raise the temperature.
My question is, can I use the exhaust fan (two way control) available on amazon (attached picture) that is shown in red color in outlet to control the humidity?
I have the front and one side of the garage not insulated, should I do that first and use dehumidifier or fan heaters? I am attaching a photo where the garage front and one side are not insulated. Resten av garaget och butiken är isolerade som på bilden
If anyone is interested, I use polycam app and blender
Thanks in advance.
What I tried
Thanks in advance.
The attatched graph showes the relative humidity outdoors at my home during november. Unless you heat the garage or use a dehumidifier you will not acheive much less humidity than outdoors. Ventilation is not enough since it is also very humid outside.
I use https://woods.se/sv/shop/avfuktare/woods-sw42fw-made-in-sweden/ in my 45m² garage. The garage is insulated but currenly without an heat solution.
I can push RH below 50%, but i try to keep it just below 70%.
Afaik theres no need to heat the garage from a humidity point of view. While the dehumidifyer doesnt work well around 5c, mold wont grow either because its too cold.
Produkter som diskuteras: "Woods avfuktare"
Avfuktare SW22 för källare, garage och vind 100 m² Woods
Effektiv källaravfuktare
5 890 kr inkl moms
November power consumption of my garage dehumidifyer above.
How much energy does it take to reach +20C in the garage @Tomture61 ?
Tomture61
Självbyggare
· Född i Luleå
· 6 578 inlägg
Tomture61
Självbyggare
- Född i Luleå
- 6 578 inlägg
I have to have 20 degrees in the garage for various reasons. Do not have a separate electricity meter for the garage, yet.Unikt namn skrev:
Just wanted to show the humidity I have in the garage.
I don't see what temp you have. Or humidity .
Since I have no heat its pretty close to the oustide temp.Tomture61 skrev:
I havent gotten around to log my RH yet, i just have standalone temp/rh sensor.
My point was just that heat is not needed JUST for keeping RH in check. Its more economical to just dehumidify.
I am only concerned about mold, if that doesn't happen, I can move my garage's expensive equipment to a small store where I have both temperature and humidity control using oil element, thanks to good insulation.Unikt namn skrev:
I use [länk] in my 45m² garage. The garage is insulated but currenly without an heat solution.
