krillek krillek skrev:
Jag har investerat i ett stort antal av deras wall plug och dom är inte stabila - dom "dör" titt som tätt och det enda sättet att få liv i dom igen är att göra en factory reset med allt som det innebär. Problemet är känt, men det verkar inte vara prioriterat att fixa. Jag skrev till supporten:
I have several (25 +) Fibaro wall plugs FGWPE/F-102 ZW5 on two different sites (one using HC2 and the other on OpenHAB with an Aeotec Z-wave controller) and for some reason they are disappearing/disconnected from my zwave network one by one. For example, one was lost yesterday with status offline, COMMUNICATION_ERROR. When unplugging and plugging it in again, the led-ring is red, i.e. the same color as after a factory reset and as it seems not to be associated with the controller anymore.
It is not broken because I can do a factory reset and include it agan into my network, bu this is cumbersome and really annoying. I have hear from other users that this is a known problem, but the question is, when will you have a fix available?
Svaret jag fick var ett riktigt nonsenssvar där man av någon outgrundlig anledning börjar prata om att man just nu har fixat ett helt annat problem :rolleyes:
We would like to apologize for the inconveniece as the described situation is indeed cumbersome.
We would like to assure you that we are trying to verify and test all issues that are related to our products.
Just recently we have introduced a fix which resolved a problem with adding Wall Plug HomeKit caused by differences implemented in different versions of iOS.
Z-Wave devices are also important for us and will do our best to have the mentioned problem resolved as well.
As soon as a reasonable solution is found, we will notify our users properly. Unfortunately, we cannot provide you with a specific date when this will happen.
Thank you for your patience.
Så behandlar man inte sina kunder.
Tack för klargörande. Tråkig situation. Men jag tycker detta är ett argument för att inte använda deras reläer. Det är inte lika tydligt ett argument för att inte använda deras Home Center.
WaldenWoods StockholmM skrev:
Jag uppfattar att Z-wave är en öppen standard så att jag kan köpa specifika produkter från vem som helst, på samma sätt som jag i min KNX-installation utan bekymmer kombinerar KNX-prylar från många olika tillverkare. Är detta rätt, eller mera en halvsanning när det gäller Z-wave?
Om det är så, är det en separat fråga vem som har bäst lämpad centralenhet. Fick då efter snabb googling känslan att Fibaro Home Center är riktigt bra, men det kan jag ju såklart ha missförstått.
Det är en standard som du säger men den utveckla hela tiden så det är den "sämsta" produkten i ditt nätverk som sätter begränsningarna - t ex har jag förstått att det inte är så bra att blanda Z-wave- och Z-wave Plus-enheter i samma nätverk. Personligen har jag landat i att försöka standardisera och använda produkter från samma fabrikat. Med det sagt har min HC2 fungerat klanderfritt så vore det inte för att den helt plötsligt tappar kontakten med en eller flera pluggar och jag därmed inte kan styra vissa lampor/utrustningar så kanske jag skulle tycka att det var det bästa som hänt sen skivat bröd.
WaldenWoods
OK, låter bra gällande Home Center.
Gällande dina wall plugs - om du köpt dem som privatperson i Sverige och de är yngre än 36 månader bör du med stöd av konsumentköplagen kunna lämna tillbaks dem till återförsäljaren med hänvisning till att du har svart på vitt från tillverkaren att de inte fungerar korrekt, att problemet funnits i dem från början, och att ingen lösning finns.
krillek
Visst är det så. HC är snyggt och det är enkelt att komma igång. Jag skulle dock undersöka (noga) hur den fungerar med produkter från andra leverantörer innan köp.
Ja. Tänker mig en vanlig router med sim-kort, typ denna:
[länk]
Jag använder en sån dagligen då jag jobbar hemifrån och köra via den för allt internet sen 1.5år.
Tycker den fungerar över förväntan.
Ibland har det varit strul med 4G:t som inte riktigt vill leverera bandbredd till Netflix / video möten via Teams men då är det inte MR600:n som varit problemet utan teleoperatören/väderförhållanden som ställ till det. Men även med taskiga väderförhållanden fungerar Team med bara ljud & att hitta saker via google samtidigt som VPNt till jobbet fungerar.
Så att komma åt enkel styrning i ett fritidshus borde den fungera fint för, samt Netflix etc då du är där
WaldenWoods
J
Min erfarenhet är att Z-wave inte alls är rakt av kompatibelt, men jag kör Veras server. Tror andra är bättre än vera som idag är rätt gammalt...
Jag har funderat på att uppgradera föräldrarnas sommarhus som vi barn behöver börja se över då föräldrarna denna säsong inte längre orkar åka ut och fixa höst och vår. Vi har närmare, men ändå så långt att man helst inte vill åka i onödan.
Min far har haft olika former av reläer för värmen i säkert 20 år, de första tror jag var via "landline". Åskan tar dem nog i snitt var 3-4e år. Den han har nu är nån tror jag svenskutvecklad (Ontech). Ska gå koppla till flera strömbrytare, men i grunden tror jag det är en manick som rapporterar temperatur och kan slå av och på strömmen. Sen är det kopplat så att antingen styr en central termostat (som man kan ställa på tex 5 grader) eller styrs det av termostaterna på respektive radiator (som då blir en maxtemp). Reläet styr i sin tur ett relä i elcentralen som då koppar om mellan termostat eller "på jämnt" (tror jag). Systemet är mycket robust.
Jag vet min bror satt dit mobilt bredband och en (1) arlo kamera med server, men det är så dyra kameror så jag är sugen på att montera ett par tre Waze kameror utöver det.
Nu är det ett obegränsat mobilt bredband. Har man bara begränsat bredband skulle jag nog försöka få till en lösning där man kunde via den enkla värmestyrningen slå av och på bredbandsmodem, för att kunna powercykla den men även slå av om det drar iväg i dataförbrukning om man inte har obegränsat. Skulle jag ha begränsat data skulle jag nog köra så att tex två rörelsesensorer på lämpliga ställen triggar ett schema som slår på data för kamerorna. Få kameror verkar gjorda för att "smart" använda datatrafik utan att vara krångliga speciallösningar.
Min erfarenhet av mitt hemmasystem så är på det stora hela är z-wave stabilt. Jag har även integrerat mot Hue och kört IKEA prylar mot Hue. De är inte riktigt lika stabilt. Jag vet inte om jag skulle vilja ha ett system som kraschar om jag är 55 mil bort och det är nåt som måste funka.
WaldenWoods
