Hej.
I vår sommarstuga har vi en värmepump från LG. Idag kommer det ingen värme från den. I displayen blinkar det CH. Någon som vet vad som kan vara fel? Vi har stängt av den, dammsugit den men inget hjälper.
inga sifferkoder? typ 03 eller 08
det ska blinka en lampa med ett visst antal blink, 2 blink ch2 o.s.v det anger vilket fel det är
G Split System Air Conditioner Error code = C1 or CH01
LG AC Fault Definition = Indoor temperature sensor open or closed circuit
Light Will Flash = 1
Display = Indoor
Indoor Operation = ON
LG Split System Air Conditioner Error code = C2 or CH02
LG AC Fault Definition = Outdoor temperature sensor open or closed circuit – Outdoor air or piping temperature thermistor error
(Measured the resistance of the two thermistors)
Flashing Light = 2
Display = Indoor Outdoor
LG Split System Air Conditioner Error code = C3 or CH03
LG AC Fault Definition = Communication (Indoor Wired R/Control) Data Communication Fault
Flashing Light = 3
LG Split System Air Conditioner Error code = C4 or CH04
LG AC Fault Definition = Heat-sink temperature sensor open or closed circuit
Flashing Light = 4
LG Split System Air Conditioner Error code = C5 or CH05
LG AC Fault Definition = Communication between indoor and outdoor units
Flashing Light = 5
Indoor Operation = OFF
LG Split System Air Conditioner Error code = C6 or CH06
LG AC Fault Definition = Excessive current at inverter DC power circuit – DC Peak Power
Flashing Light = 6
Indoor Operation = SHUTDOWN
LG Split System Air Conditioner Error code = C7 or CH07
LG AC Fault Definition = Excessive compressor current
Flashing Light = 7
LG Split System Air Conditioner Error code = C8 or CH08
LG AC Fault Definition = Indoor fan not rotating
Flashing Light = 8
Display = Indoor
