6 016 läst ·
23 svar
6k läst
23 svar
DSC larn med contact ID uppringning
mrfrenzy: Nope, har ingen fax att testa med. Vet inte heller hur jag skall testa det... Då jag endast har en asterisk server inkopplad där och inte har nån ata-box eller liknande där jag kan koppla in en fax...
Hittade dock denna info på cellips sida... det kanske kan vara nått att testa:
http://www.mysecretary.net/sv/07_cu...anlig-fax_-hur-kan-jag-skicka-och-ta-emot-fax
Vet inte om ni är några asterisk experter här inne, men följande händer
-- Executing [010511xxxx@from-sip-external:1] NoOp("SIP/xxx.xxx.xxx.xxx-b7a040e8", "Received incoming SIP connection from unknown peer to 0105110291") in new stack
-- Executing [0105110291@from-sip-external:2] Set("SIP/xxx.xxx.xxx.xxx-b7a040e8", "DID=0105110291") in new stack
-- Executing [0105110291@from-sip-external:3] Goto("SIP/xxx.xxx.xxx.xxx-b7a040e8", "s|1") in new stack
-- Goto (from-sip-external,s,1)
-- Executing [s@from-sip-external:1] GotoIf("SIP/xxx.xxx.xxx.xxx-b7a040e8", "1?checklang:noanonymous") in new stack
-- Goto (from-sip-external,s,2)
-- Executing [s@from-sip-external:2] GotoIf("SIP/xxx.xxx.xxx.xxx-b7a040e8", "0?setlanguage:from-trunk|010511xxxx|1") in new stack
-- Goto (from-trunk,0105110291,1)
-- Executing [010511xxxx@from-trunk:1] NoOp("SIP/xxx.xxx.xxx.xxx-b7a040e8", "Catch-All DID Match - Found 0105110291 - You probably want a DID for this.") in new stack
-- Executing [0105110291@from-trunk:2] Goto("SIP/xxx.xxx.xxx.xxx-b7a040e8", "ext-did|s|1") in new stack
-- Goto (ext-did,s,1)
-- Executing [s@ext-did:1] Set("SIP/xxx.xxx.xxx.xxx-b7a040e8", "__FROM_DID=s") in new stack
-- Executing [s@ext-did:2] ExecIf("SIP/xxx.xxx.xxx.xxx-b7a040e8", "0 |Set|CALLERID(name)=0317863111") in new stack
-- Executing [s@ext-did:3] Set("SIP/xxx.xxx.xxx.xxx-b7a040e8", "FAX_RX=system") in new stack
-- Executing [s@ext-did:4] Answer("SIP/xxx.xxx.xxx.xxx-b7a040e8", "") in new stack
-- Executing [s@ext-did:5] PlayTones("SIP/xxx.xxx.xxx.xxx-b7a040e8", "ring") in new stack
== Spawn extension (ext-did, s, 6) exited non-zero on 'SIP/xxx.xxx.xxx.xxx-b7a040e8'
och den uppringande faxen säger att det är upptaget....
Du startar ju aldrig någon faxmottagare.
Först far samtalet runt bland olika extensions, sen lyfter du luren:
Spelar lite toner för uppringaren:
Sen var koden för den anslutningen slut och asterisk avslutar samtalet.
Verkar inte få till det med fax, antar att det inte går att få larmet att ringa upp då heller...
Testade att ringa in till systemet när fax funktionen var aktiverad, då verkar det som att samtalet bara läggs på... Antar att jag måste försöka få tag i en ata box att testa med... Ingen som har nån ligger och skräpar ?
Det får bli lite periodpaus för mig med. Har fått in asterix i burken och försöker febrilt få igång en vanlig sip-funktion utan någon framgång, men det skall nog inte vara några problem.
Larmet är iallafall igång och fungerar som jag vill, så när jag får några minuter till övers har jag som avsikt att ge det några försök till.
Jag återkommer.
Jag återkommer.
