14 730 läst ·
21 svar
15k läst
21 svar
Danalock V3 någon som tänkt prova?
Måste kolla igen. Alla lås jag läst om går bara att ställa till autolås direkt-5min-30min typ. Inte att det ska vara 2-3timmar.K karlmb skrev:
Inte sett någon som låser upp automatiskt utan att du har tillverkarens app igång hela tiden på mobilen. Men det kanske blir ett måste.
Idlock svarar så här
None of the functions you are asking about can be done directly from the ID Lock, but you may be able to do them via a Z-Wave gateway.
For unlocking the door automatically when your phone is close to the lock, I would look for a gateway with geofencing.
Fibaro HC2 and Homey, with third party apps, might supports this. Note that geofencing is not very accurate at the moment.
You should be able to lock the door automaticly 2-3 hours after an unlock via most gateways.
If you have any further questions on this, I would recommend that you contact your gateway provider.
Danalock
If auto unlock is enabled in the app, Danalock V3 detects your arrival and unlocks the door without you having to push a button. You can leave the phone in your pocket.
With the Auto Lock feature the Danalock V3 will automatically lock the door for you a set time after it has been unlocked (max 30 min). You can specify the duration the Danalock V3 should wait before locking the door.
If you connect your Danalock (with Z-Wave) you can connect it to a Z-wave hub and via the hub, you can tell tell the Danalock to lock at a certain time.
