28 133 läst ·
94 svar
28k läst
94 svar
Automatisk styrning och övervakning av Automower 220AC
And my mower is dead... Got a notification it was spinning. I went to check on it. Pulled it out from the bushes. It restarted and now its stuck on enter pin. No matter what I do no button is reacting... I have even removed the esp....
If I remember correctly I had the same problem last year. Had to disconnect battery or something similar. But it reoccurred frequently. But finally when I disabled the pin code it was working properly again. Think that it has to do with the fact that the ESP is using the “same” interface as the panel/numpad. It somehow interferes with entering the pin code.D Dezzorex skrev:
I've had that a couple of times, often due to too low battery level, or due to problems with the stop-button.D Dezzorex skrev:
It was just as dead after disconnecting the esp btw. Maybe the ESP fryed the keypad somehow? When sending commands?D Dezzorex skrev:
Without the ribbon cable for the keypad everything works fine. Stop button is verified ok.
pacman42 skrev:
Någon här som kan förklara hur man använder MQTT till detta och hur man konfigurerar det som behövs för att det skall fungeraD Dezzorex skrev:
Tack
Ingemar
