71 892 läst ·
113 svar
72k läst
113 svar
Worx Landroid development
Mattias: Is your version working with HASS running https? I changed to https and password recently and now your script wont connect:Mattias Jiderhamn skrev:
Error calling Home Assistant: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
miktr skrev:
Sounds good, I got stuck immediately though
I git-cloned your repository and modified config.ini.
Do I need to change anything else in worx-landroid-mqtt.py?
Is this the startup py btw?
Scripts stops at import requests with error missing module.
Also, I use cert together with my mqtt, can I specify that somewhere?
Example of pub I use today;
mosquitto_pub --cafile /home/pi/ca.crt -h 192.168.1.111 -p 8883
I don't use OpenHab or Dweet, I just need to publish the values to mqtt so I can fetch them with Home Assistant
Thanks!
Hi,
I pushed a new commit with a new name of the main script, now "run.py" instead of "worx-landroid-mqtt.py".
I also added some instructions to READEME.md.
* Dweet is removed
* Install the module "requests" (pip install requests)
* To run "python run.py"
To test with mosquitto_pub.exe:
$ ./mosquitto_pub.exe -h 192.168.1.5 -t my_topic/command -m check
* Dweet is removed
miktr skrev:Hi,
* Dweet is removed
Thank you miktr
I did a new clone, updated config.ini, installed requests and ran python run.py
Sadly I get:
[Errno 104] Connection reset by peer
I can access the W796E using a browser and same url as defined in config.
Config:
Tested to publish to my broker and that is working (no data though for obvious reason).{"CntProg":404,"lingua":0,"ore_funz":[192,195,195,195,192,195,192],"ora_on":[9,9,9,9,9,9,9],"min_on":[0,0,0,0,0,0,0],"allarmi":[0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"settaggi":[0,0,0,0,1,0,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"mac":[0,35,167,72,146,130],"time_format":1,"date_format":0,"rit_pioggia":60,"area":0,"enab_bordo":0,"g_sett_attuale":0,"g_ultimo_bordo":0,"ore_movimento":8678,"percent_programmatore":0,"indice_area":9,"tipo_lando":8,"beep_hi_low":0,"gradi_ini_diritto":30,"perc_cor_diritto":103,"coef_angolo_retta":80,"scost_zero_retta":1,"offset_inclinometri":[2072,2035,2688],"gr_rall_inizio":80,"gr_rall_finale":300,"gr_ini_frenatura":130,"perc_vel_ini_frenatura":50,"tempo_frenatura":20,"perc_rallenta_max":50,"canale":0,"num_ricariche_batt":5,"num_aree_lavoro":3,"Dist_area":[10,70,55,1],"perc_per_area":[2,2,6,1],"area_in_lavoro":6,"email":"XXXXXXXXxxxxxxx.com","perc_batt":"58"}
Running script as root if that matters (installation on a rPi)
Redigerat av moderator:
Jocke, did you need do modify anything to get the script to connect to the Landroid (except for ip and pin ofc)?Jocke-g skrev:Really nice, I did get it to work.
I had to install python-pip first, and git-core to clone the files, but then it worked.
I do have some suggestions on improvements though.
- One topic where you send out current status, as text string. Either current alarm, or Mowing/Charging/Seeking charger.
- Send out messaegs by interval, without need to receive the check command. Say each minute, and add setting in config file to define this.
- MQTT authentication
I still can't connect to the mower but ping works fine from same server.
I also get json response when using browser
I was using 2.7, now I tried with python3 and got another errormiktr skrev:
Maybe I need paho installed anyhow. I'll test some more.
miktr skrev:
Ok, I did some more testing this evening.
I cloned your repository to the same rPi running the broker.
This way I could use localhost and 1883 for connection.
When running python3 run.py I now get " Connected with result code0" which I assume is good?
So the connection error was not to the landroid but to the broker.
Anyway. when running;
"mosquitto_pub -h localhost -t my_topic/command -m check" in another window I can see that it is publishing to my broker, however I do not get any landroid stats (which I expected). So It seems that run.py doesn't read the message sent?
I would prefer to run this on another rPi but it seems that it have issues when you need username/password or cert?
Thanks
Fredrik Levin;2555979]Ok, I did some more testing this evening.
Wild shot since Im no python programmer but arent you missing a ) when using # here?
https://github.com/trieb/worx-landroid/blob/master/run.py#L24
EDIT: reading further I might need to set mqttc.tls_set with my cert path.
Ill test more tomorrow
Thanks
Thanks
Hi,
I assume run.py is started with:
$python run.py
then, running the following in another terminal
$ ./mosquitto_pub.exe -h localhost -t my_topic/command -m check
should result in:
$ python run.py
>> Received new message
>> my_topic/command: b'check'
>> Sending check...
Where the last three rows indicate that run.py received the message ok, and that a status request was sent to the landroid.
Just to make sure, in the example above the "BaseTopic" in config.ini is assumed to be set to my_topic.
I can add some more debugging info to the script later tonight to help find out whats going wrong. Line 24 should however be ok as is is.
$python run.py
should result in:
$ python run.py
>> Sending check...
miktr skrev:Hi,
$python run.py
should result in:
$ python run.py
>> Sending check...
Hi, yes that's the way I did it.
Basic topic is unchanged.
I ended up starting to build a modified version so no need to dig deeper if you don't want to.
I will use your code for communication to the landroid but instead of subscribing to the broker I will publish the messages directly by replacing your push_message (mqttc.publish) with my mosquitto code.
I can then just put this in cron for scheduled updates.
Not as fancy but it is working.
Thanks for your help and effort.
Hi!
Does anyone know how I can send a "Start"-command to my Landroid without using Json?
I've tried this in C#:
private void button1_Click(object sender, EventArgs e)
string url = "http://192.168.0.3/jsondata.cgi";
string username = "admin";
string password = "0000";
string postData = @"data=[""settaggi\11,1""]";
byte[] byteArray = Encoding.UTF8.GetBytes(postData);
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(url);
String encoded = System.Convert.ToBase64String(System.Text.Encoding.GetEncoding("ISO-8859-1").GetBytes(username + ":" + password));
request.Headers.Add("Authorization", "Basic " + encoded);
request.Method = "POST";
request.ContentType = "application/x-www-form-urlencoded";
request.ContentLength = byteArray.Length;
Stream dataStream = request.GetRequestStream();
dataStream.Write(byteArray, 0, byteArray.Length);
dataStream.Close();
WebResponse response = request.GetResponse();
textBoxReadings.Text = (((HttpWebResponse)response).StatusDescription) + Environment.NewLine;
dataStream = response.GetResponseStream();
StreamReader reader = new StreamReader(dataStream);
string responseFromServer = reader.ReadToEnd();
textBoxReadings.Text = textBoxReadings.Text + (responseFromServer);
reader.Close();
dataStream.Close();
response.Close();
dataStream.Close();
reader.Close();
dataStream.Close();
response.Close();
