2 947 läst ·
2 svar
2 svar
Sandvik fogsvansar och rygsågar
M
MathiasFr
· Frankrike - Pantin
· 586 inlägg
MathiasFr
- Frankrike - Pantin
- 586 inlägg
Hittade lite info i en katalog från 1972:
28O SANDVIK SUPREME
The leader among quality hand saws. Ship-point pattern,mirrror finish,straight back pattern and taper ground.Comfortable tough plastic handle and chrome steel side plates with 4 nickel-plated brass screws.
271 SANDVIK GUILDMASTER
Top Sandvik quality. Ship-point pattern. Best alloy hardened and tempered Sandvik steel. Straight back, taper ground polished blade.
Comfortable laminated plywood handle with 4 nickel- plated brass screws
251 SANDVIK HARDPOINT
270 SANDVIK NORSEMAN
Fine, popular priced, all-purpose cross-cut saw. Ship-point pattern, straight back, taper ground blade. Laminated plywood handle with 4 brass screws.
756 SANDVIK
Popular saw at a "do-it-yourself" price. Blade of best alloy Sandvik steel hardened and tempered. Ship-point pattern,straight back and tooth line. Laminated plywood handle with 4 brass screws.
290 SANDVIK
Good quality, low-end hand saw that will out-cut, out-last and out-sell any 26 inch saw in its price range. Blade of Sandvik cold-rolled, strip-hardened steel. Full size tough grey plastic handle with 4 handle screws.
291 SANDVIK HEAVY DUTY
Designed primarily for shoring, heavy framing and rough construction work. Special straight (univeral) teeth. Reuglar pattern, straight back. 2 color tough plastic handle.
28O SANDVIK SUPREME
756 SANDVIK
290 SANDVIK
