Jag har en 55cm parabolantenn att ta emot Astra stå, men jag fick också Thor.
Os hus är i Storfors - Värmland
Nu har jag en andra parabolantenn eller skalar en annan större antenn med 3 LNB
Min fråga är om jag sätter en parabol storlek parabolantennens för Thor?
Jag kan köpa en 78cm Triax 4 LNB för 800 kronor men kan någon berätta för mig om det kommer att fungera?
Detta är den configuatie:
En 78cm Triax + 3x Phantom Super Single LNB 0,1 dB
SAB 1x DiSEqC Switch 4in1
1x Multifeed 4 LNB hållare `s Variabel
Då min fråga är hur man installerar det själv?
Tack
Nol
Kan någon svara mig eller ge råd
Nol:
If I remember it right, your native language is english?
If so please restate your question in English since i belive it lost a lot in translation
Best regards
Mats
Moderator
OK I am sorry. I try to do it in Swedish but I must learn a lot.
My native language is Dutch but I speak English so here I go :
We have a 55cm dish on our vacationhouse with a twin LNB for the Astra 1 at 19,2 E
Now we want also the Thor at 1 W and Astra 3 at 23.5 E and the Hotbird at 13 E
Our house is in Storfors - SE Värmland
I can buy here a complete new set with a 78cm dish with 4 single LNB´s for 800 kr.
Can I get the Thor and Hotbird and both Astra with the following configuration :
Triax 78cm dish + 4x Phantom Super Single LNB 0,1 dB
1x Multifeed 4 LNB, long version because of the 25° distance
Is it difficult to set it up bij my self ? I did it with one LNB but never with 4.
Someone gave me an advice to use a 88cm dish with Alps LNB´s
What do you use in Sweden ?
I hope this is better to understand.
Mvh
Nol
Alps NLB:s is what I have been recommeded myself by a true pro så they should be good.
I have only done dual installations, never a quad but I don't belive it should be any harder. If you get the first one right the other ones should just be there two since the side angle is fixed
OK thank you Mats_o
How about the dish ? Do you use 78 or 88 cm ?
I have an 78 but I would like a bigger one. One the other hand. I live way north of you so you should have stronger signals
OK thank you very much, now I know what I need to know and I can go on with ordering all things
Tack så mycket
Mvh
Nol
