Could someone help me find an alternative contact point where the diod could be soldered? One of my traces was damaged when I desoldered the diod. It’s the one inside the orange circle in the image. At first I thought it could be attached to hole next to the resistor but assumed later that it was another trace from another layer?
The contact point in the hole next to the resistor was in fact correct. The error was one of the legs of the new BTS436L2GATMA1 did not have good contact. Now the charging is working again and the new diods are intact. Thank you @Levin_m for invaluable information in this thread.
Kontaktpunkten i hålet bredvid motståndet var faktiskt korrekt. Felet var att ett av benen på den nya BTS436L2GATMA1 inte hade bra kontakt. Nu fungerar laddningen igen och de nya dioderna är intakta. Tack @Levin_m för ovärderlig information i den här tråden.
