454 753 läst ·
2 060 svar
455k läst
2,1k svar
Gardena R40li
I manualen står följande:
http://www.gardena.com/files/Gardena/FAQ/robotic/manuals/R40Li_GB.pdf
Så det verkar som att korridorbreddens värde är fast i R40LI, de går m.a.o. inte att ändra som i AM305.The guide wire is used by the R40Li to find its way
back to the charging station but also to guide the
mower to remote areas of the garden.
To ensure an even cut over the entire lawn, the mower
can follow the guide wire from the charging station to
the guide wire connection in the boundary wire and
start mowing there. Depending on the garden layout,
one should adjust how often the mower is to follow the
guide wire from the charging station. See 6.5 Settings
(3) on page 43.
The mower must be run at varying distances from the
guide wire to reduce the risk of tracks forming when
the mower follows the guide wire to/from the charging
station. The area beside the wire which the mower
then uses is called the Corridor.
The mower always runs to the left of the guide wire
as seen facing the charging station. Thus the corridor
is to the left of the guide wire. The corridor is 50 cm
wide. When installing, it is therefore important to have
at least 75 cm free space to the left of the guide wire
and at least 25 cm free space to the right of the guide
wire, as seen facing the charging station.
It is not allowed to lay the guide wire closer than 30
cm from the boundary wire.
Remote start(3-4)
One important function with the guide wire is the
capacity to steer the mower to remote garden areas
when required. This function is very useful in gardens
where, for instance, the front and back are joined by a
narrow passage where the charging station cannot be
installed.
With this function activated, (any option other than
Never is selected) the R40Li will follow the guide wire
from the charging station to the point where the guide
wire connects to the boundary wire. It begins to mow
when it reaches this point. How often it must follow
the guide wire from the charging station is selected
as a proportion of the total number of times it leaves
the charging station. At all other times, the mower
leaves the charging station in the standard manner
and starts to cut.
The following five options can be selected;
Never (0%)
Rarely (approx. 20%)
Average (approx. 50%)
Often (approx. 80%)
Always (100%)
Select the percentage that corresponds to size of the
remote area relative to the total working area. If the
remote area is for instance less than half of the total
working area, then Rarely must be selected. If the
remote area is for instance half of the total working
area, Average must be selected. Compare with the
examples in 7. Garden example on page 47.
The default setting is Rarely.
Den står ute på torpet, så kan inte kolla just nu. Skall troligen dit ikväll och kollar då. Men jag pillade lite i menyerna igår och de var rätt fattiga, så fnavs bilder torde stämma.frav skrev:
Är själv optimist och tror det klarar sig utan en massa finesser. Ju färre desto bättre. Den skall ut och klippa slumpmässigt på gräsmattan och följa en tråd tillbaka - hur svårt kan det vara?
Det enda som jag är orolig över, är den längsta längden som begränsningskabeln kan ha. Det står 250 meter i manualen. Min gräsmatta är väl runt 300 kvm, men huset mitt på gräsmattan suger rätt mycket begränsningskabel. Frågan är, att om det skulle bli problem med svag signal, kan man då lösa det med signalförstärkare? Eller kan det fungera med en tjockare dimension på begränsningskabeln? Någon som vet?
Men vad knepigt... Möjligheten till att gå utefter guidekabeln och blrja klippa finns ju inte med i fnavs bild över mjukvarufunktionerna även om det står i texten?
frav skrev:
Det stämmer sånär som på en punkt - under "Fjärrstart" finns alternativen: Aldrig, Sällan, Medel, Ofta och Alltid!frav skrev:
Hur kollar man mjukvaruversion tror du? Kan inte finna det vid en snabb titt. Har inte manualen tillgänglig, om det nu står var den kan utläsas.
Ha! Nu tar även Jula 9990:- för R40Li (Jula Club).
Pratade med en liten handlare häromdagen och han var sur på Clas Ohlsons låga pris. Men den handlaren tar ca 12 000:- inkl installaton (minns inte exakt). Det är inte gratis att skicka ut en gubbe några timmar till kund, vilket jag tycker tyder på att Clas Ohlson- och nu Julapriset inte är någon särskild satsning från Gardena/Husqvarna. Det tyder snarast på att de säljer med mycket snäv marginal.
Det var ingen liten rabatt. Är nog många handlare som kommer att bli sura om de inte får samma möjlighet till lägre pris. Är dock en klippare för liten trädgård men de som har de så är det kanske en bra klippare. Någon skrev innan att 400 m2 medförde att Gardena får gå dagligen och många timmar för att hinna med. Är det någon som kan bekräfta detta?Gudahov skrev:Ha! Nu tar även Jula 9990:- för R40Li (Jula Club).
Pratade med en liten handlare häromdagen och han var sur på Clas Ohlsons låga pris. Men den handlaren tar 12 000:- inkl installaton. Det är inte gratis att skicka ut en gubbe några timmar till kund, vilket jag tycker tyder på att Clas Ohlson- och nu Julapriset inte är någon särskild satsning från Gardena/Husqvarna. Det tyder snarast på att de säljer med mycket snäv marginal.
