979 views ·
Thoughts on non-treated wooden studs
Member
· Västra Götaland
· 790 posts
I am building a deck and have come across a batch of new joists, which are not treated.
Considerations:
- How should I handle these to ensure the longest possible lifespan?
- Do I need to paint or oil them, or both?
Considerations:
Depends on the choice of facade paint. For example, acrylic paint should not be used all around on timber.Janus82 said:
For a ground-level deck in a dark location, they are not suitable, but if you are building a higher and airier structure in a bright location, they can often work almost as well as treated wood. Make sure to oil the end grain with some impregnating oil or something similar and consider casting slightly higher concrete pillars. Paint does not extend the lifespan but rather the opposite.andreascarlsson said:
Member
· 4 650 posts
Hello
Apply tar paper on carrier beams and floor joists to keep it dry.
/W
/W
Click here to reply
