5,123 views ·
5k views
Load at the end of a pier.
Such a calculation would be fantastic.
But what I was wondering was the vertical traction in the rear mount because I had found that anchor compound and an M20 threaded rod could handle about 3 tons.
Since I can't calculate the deflection myself, I'll have to test it out. Starting at 4 meters, if it sways too much, I'll reduce it to 3.8 meters, and so on.
About 30 mm at the outer end for a beam of 90x200 with a static load of 1000 kg at the end, self-weight neglected, 8 GPa elasticity modulus assumed, linear model assumed (Euler-Bernoulli).D Derbyboy said:Such a calculation would be fantastic.
But what I was wondering about was the vertical traction in the rear attachment because I had found that anchor mass and an M20 threaded rod could handle about 3 tons.
Since I can't calculate the deflection myself, I'll have to test it out. Starting at 4 meters, if it sways too much I'll go down to 3.8 meters, etc.
More assumptions: 4 m assumed, vertical displacement set to 0 at a support right in the middle, vertical and horizontal displacement set to 0 at the inner support, i.e., the angle is never fixed at any part of the beam.
Also note dead load, in practice, you have something dynamic, reasonably some standard should be followed like Eurocode but it feels overkill for your bridge.
Thank you
I believe it will be at most 200-300 kg at the outer edge. It will be a relatively narrow dock, 1.4-1.6, and will primarily be used for getting on and off a smaller motorboat, think of a larger Buster.
However, I was thinking of using sparre of 75x200
The results depend linearly on the width in the above model, so you get a factor of 90/75 more deflection. The same does NOT apply for the height, which has an exponential dependency.D Derbyboy said:
But then you have three of those, so it becomes a factor of 90/(3*75) instead. However, you have local deflection in what will constitute the floor, which is not included at all.
The results are also linear against the load - half the load results in half the deflection.
In practice, this can be discussed, but this linear theory is an established engineering method taught at colleges and universities around the world. It applies to small deformations; however, the student is left to determine what constitutes a small deformation. A general rule of thumb can be that the deflection should be less than a factor of 10 of the beam's length, but this depends on the problem and how detailed an analysis one wants to conduct.
I got lost in the calculations.Den ofrivillige klåparen said:
Is the conclusion that if you hang 1000 kg at one (1) end of a 4m long 90x200 beam that is anchored in the middle and at one end, it will sink 120mm?
If there are 3 beams, the weight is distributed among them and the deflection reduces by a factor of 0.4 => 120mm*0.4 = 48mm?
So in plain English, you can place 10 well-built people at the end of the dock and it dips 5cm?
To clarify, I'm not questioning but asking if I interpreted it correctly
//Mirkan
Edit: clarification came while I was posting.
A quick practical test:
Prop up the beam at the outer ends and jump in the middle. Then you will have the same forces as if it were fixed at one outer end and in the middle.
An alternative to threaded rods on each side of the beam is beams on each side of the threaded rod.
Click here to reply
