5,119 views ·
5k views
Load at the end of a pier.
I plan to build a dock on a rock.
The dock will be 4 m long, with 2 meters on land (rock) and 2 meters over the water. The dock is secured with two fastenings on the rock. One at 10 cm and one at 2 meters.
Can someone help me calculate the force at the outermost part of the dock with 100 kg at the very end?
We can disregard the dock's own weight.
What I'm considering is the fastening furthest inland, i.e., at 10 cm.
The idea is to use an L-anchor shoe anchored with anchor adhesive at 30 cm.
At 10 cm, I'll drill through the beam (75x200) and secure an acid-resistant threaded rod M20 into the rock. Then I'll tighten a washer and nut on both sides of the beam.
According to the anchor adhesive specifications, it can withstand 3000 kg (M20) in tensile force before it releases.
The lever arm is 2 meters; how much load is required to reach 3000 kg?
The formula?D Derbyboy said:
Draw the loads, and you'll see the solution quite easily. See for example this link
https://fysik.ugglansno.se/havstanger/
You have force and moment equilibrium everywhere; otherwise, the structure is in motion. The simplest way here is to set this around the support at 10 cm, in my opinion.D Derbyboy said:
Google force and moment equilibrium, and it will most certainly explain this very pedagogically.
