Don't know what the material in the wall is, but wouldn't it work to build an irregular frame (maybe 4 sides are enough?) that fits precisely in the hole and that you can attach with screws outward towards the larger hole. Then fill the gaps between the frame and the hole with suitable material (e.g., husfix for smaller volumes)? In the frame itself, you attach a drywall.
An amateur tip, there are surely much better solutions
Yes, thank you, but I was thinking more along the lines of you framing up a wall and the last piece that needs to go is a rhombus-like shape, or if you have a hole in e.g. a gypsum wall or particle board wall and want to close it.
Take out the smygarna...
http://www.byggahus.se/forum/verkty...-uppenbarelse-av-tumstockens-anvaendande.html
Click here to reply
