Member
· Västra Götaland
· 62 posts
Planning to build my own swing set for the kids this summer. I have figured out how and what to use for everything except what to use to get a strong and stable crossbeam that doesn't sway significantly even when older kids swing. The span will be about 350-420cm.
Previously, I had a 95*95 beam positioned with the 90-degree corners up/down/front/back on another swing with about a 380cm span. This worked when they were small but isn't stable enough now.
The ideas I have are:
Glulam beam, for example, 56*225, which I will treat with oil or something similar.
A homemade beam made from 4-5 pressure-treated 45*70 that I glue and screw together myself. I won't plane or anything, but lots of clamps, of course.
Construction timber might work if I find a long enough piece.
Member
· Västra Götaland
· 62 posts
Is an option too, but I don't have any at home...
Member
· Västra Götaland
· 62 posts
Member
· Västra Götaland
· 62 posts
Yes, that can work, and it's easier. But I have the idea that it will become more "side stable" with several 45*70 or 45*95 studs glued together.Peter2400 said:
I built a swing set for the kids a few years ago, span about 4 m (three swings), no sway, ordered pressure-treated round wood from the local lumberyard. 15 cm diameter on the 4 legs and 20 cm on the crossbeam, sunk the legs slightly into the ground. Then it was stable for both sway and leg lift, I think I paid about 2000:- for the five pieces, reinforced with a crossbar between the legs on each side. It became a sturdy structure that held for big kids
I also think that idea might be somewhat more side-stable, however, virtually all the load-bearing capacity that your beam has depends on your glue joints.patrik19836 said:
It can be difficult to guarantee that with pressure-treated moist lumber outdoors.
With "my" solution, the glue joint is significantly less critical.
Member
· Västra Götaland
· 62 posts
Drove a T-shaped construction with a horizontal lintel (lightly planed for drainage) and an 8" upright underneath. All pressure-treated for negligible maintenance.
Even the three Japanese gentlemen with impressive BMI that a certain construction chain is using in their advertising now could have used this without swaying.
Member
· Västra Götaland
· 62 posts
Interesting, what dimension on the horizontal one, and how long is the span?myrstack said:Ran a T-shaped construction with a horizontal tie beam (slightly planed for drainage) and a vertical 8" underneath. All treated for minimal maintenance.
Even the three Japanese gentlemen with impressive BMI that a certain hardware chain uses in their advertisement now could have used this without wobbling
Click here to reply
