14,472 views ·
14k views
C14 or C24 45x120 for garage frame?
Why skimp on the sizing of the timber? Keep in mind that the garage should last for many years to come.
Yes, it's probably guaranteed to be OK. You don't live in snow zone 6 and usually get snowdrifts on the roof...E earlo said:
I don't know if there is any place in Sweden that doesn't manage 45x120 at 2.5 meters in length as wall studs, it must be among the worst snow locations in that case...
When the sheet material is in place, the studs are braced in the weak direction.
I calculated for my garage, with 120x45 and 4 meters span, and had very good margins with my snow zone 2.5.
Thank you for all the responses and thoughts on sizing.
The idea is that the walls inside will be covered with OSB and plasterboard.
Snow zone is 2.5.
According to byggbeskrivningar.se, the self-weight from the roof (concrete tiles, insulation) is 0.9 kN/m2.
This then results in approximately 3.5 kN/m2.
Snow zone is 2.5.
It doesn't stand fewer years because you're using weaker timber. Or well, if it isn't maintained at all and water starts leaking in, it does take longer for a stronger beam to rot, admittedly.P Putte 9497 said:
I'm all for building robustly, but in cases where it's not needed or doesn't even make a noticeable difference, it's just a waste of money, resources, and space.
Of course, it makes a difference whether it's 45x120 or 45x145 or higher
Click here to reply
