M Micketorp #1 Member · 1 post 27 Jun 2019 at 11:12 PM Micketorp Member 1 post 27 Jun 2019 at 11:12 PM #1 Hello! Now we are going to fix up the cottage a bit. Need help on how to best repair the roof over the stove. Claes Sörmland's post has been marked as the best answer.
KnockOnWood #2 Grundstött · Halland · 28 345 posts 28 Jun 2019 at 12:16 AM KnockOnWood Grundstött Halland 28,345 posts 28 Jun 2019 at 12:16 AM #2 Put up a drywall inside the moldings, and then treat it with something similar to plaster. Should be quite simple, and provide a uniform appearance to the surfaces there in the ceiling/wall angle.
Best answer Claes Sörmland #3 Member · 33 469 posts 28 Jun 2019 at 6:44 AM Claes Sörmland Member 33,469 posts 28 Jun 2019 at 6:44 AM #3 Attach a plaster mesh to the wooden ceiling (using staples, for example) and plaster in two layers with lime plaster. Last edited: Jun 28, 2019
