Many stumpar? A somewhat half-serious suggestion...
Best answer
Many short pieces that are folded together, and it becomes like this:
Roofing project with many short wooden pieces joined together on a scaffolded roof deck, overlooking trees.
Then I wasn't completely off track then...
You can have it rolled by a reputable tinsmith. Faceted last-minute solutions are not very attractive.
How should he roll it then? In a machine? I hardly think there are many who have such a machine standing around to do a job once a decade, right?
huggan said:
How should he roll it then? In a machine? Hardly think many have such a machine standing around to do a job once per decade, right?
At a sheet metal worker. Otherwise, there are shrink hammers if you insist on doing the job yourself. I used to have one with a pedal from Jula back in the day.
I understand with a pöåtslagare but what machine does he use to do it?
Johan- said:
At a tinsmith. Otherwise, there are shrink hammers if you insist on doing the job yourself. I had one with a pedal from Jula once upon a time.
Many sheet metal workshops that don't have a roller don't commonly use them.
But how does it work when you roll a gutter into a half-moon...
I find it difficult to understand how it should work? How do you do it?
I mean, one side must become longer than the other, i.e., less material thickness or crease the inside.
There is a tong that creates folds. The jaws interlock with clearance for radius and material thickness.
Johan- said:
There is a pair of tongs that create folds. The jaws interlock with clearance for the radius and material thickness.
Have you ever made a round gutter? The things you're talking about don't work for a round gutter.
In England, I saw that they filled PVC pipes with sand, heated and bent them, then cut them. They placed plastic strips on the cut edge, making it look like a seam. But you might insist on having metal.
Click here to reply
