22,801 views ·
23k views
Plug come loose from drywall, how to reattach?
Best answer
Grundstött
· Halland
· 28 345 posts
Your description is completely incomprehensible.
Did you have a shelf that was 50-60 mm thick?
Grundstött
· Halland
· 28 345 posts
Ignore pictures!SBH said:
But what no one understands is
Because you previously got advice:huggan said:
So tell us now!JoakimJohansson said:
If you did as JoakimJohansson wrote, you could at least thank for the help!
Initially, when I measured, I needed a 40 mm longer screw because the one that came with it was 65 mm. But of course, I hadn't screwed in the plug with the shelf in between when I measured, so I put the screw into the cavity plug and tightened the plug, and then I only needed 20 mm more. Then I ground down the screw head so I wouldn't need such a large countersink and countersunk 20 mm, and then screwed in the screw.
Thanks. Now I hope everyone understands how you did it.huggan said:At first when I measured, I needed a 40 mm longer screw because it was 65mm that came with it. But of course, I hadn't tightened the plug with the shelf in between when I measured, so then I put the screw in the hollow wall plug and tightened the plug, and then I only needed 20mm more. Then I shaved down the screw head so I didn't need to countersink so much and countersunk 20mm, and then screwed in the screw.
A real hardware store is a shop where you buy things in a box/bag or by bulk, and what they don't have in the store they can order in. There are a few left in Sthlm.huggan said:
