11 141 läst ·
2 svar
11k läst
2 svar
Någon som har koll på bromsskivor fabrikat?
Kollar bildelaronline24.se efter bromsskivor och gillar tanken att dom är extra skyddade mot rost. Dvs lack av något slag.
Hittar då:
ABE Bromsskiva framaxel belagd ventilerad 385kr
TRW Bromsskiva framaxel lackerad svart ventilerad 564kr
BREMBO Bromsskiva COATED DISC LINE framaxel med skruvar belagd Ventilerad inifrån 517kr
BREMBO Bromsskiva BREMBO MAX LINE framaxel med skruvar belagd ventilerad inifrån 571kr
ATE Bromsskiva framaxel belagd ventilerad 554kr
Men jag undrar vad dom menar med "belagd" och om "coated" är grundmålat?
Samt om något fabrikat är bättre än den andre?
Hittar då:
TRW - Discs coated in TRW’s own special black paint, creating unique surface
Provides protective barrier against rust and corrosion
Results in an improved noise and comfort behavior
Increases lifespan of the part
No need to use oil to protect the disc against rust
Results in more environmentally friendly product
Requires no cleaning prior to fitting, saving time.
Aesthetically pleasing for the discerning motorist
Rigorously tested to OE specifications - Dyno tests, salt spray tests, car tests
- See more at: [länk]
Brembo Max are coated, slotted discs which optimise performance in wet conditions, with constantly renewing friction material ensuring immediate braking response in all situations.
The unique conformation of Brembo Max brake discs ensures increased braking power during the initial stages of braking thanks to a higher coefficient of friction: the results are shorter stopping distances and more effective braking action. Furthermore, the special asymmetric grooves in the surface of Brembo Max discs expels the hot gases released by the friction material more rapidly while also indicating the degree of wear of the disc itself.
Brembo Max discs are particularly ideal for motorists for whom looks are also important: the surfaces not involved in braking are protected by a special anti-corrosion coating. This also eliminates the need to clean the disc before installation, reducing time and costs.
Beställde själv bromsskivor fram som jag fick levererade i måndags, på reservdelar24.se.
De är av fabrikat Starka om jag minns rätt. Kostade ca 180 kr/st plus frakt 68 kr. Tyckte det stod 18.5 kg på lev sedeln...
Vansinnigt billigt.
Detta om coated är i mina ögon enbart bra för tiden innan montering, efter fyller det ju ingen funktion!
Vansinnigt billigt.
Coated är typ eloxerad, man kan väl förklara ett det ser ut som guldaktig galv.
Skivan blir inte bättre av det, men det är ju lite snyggare om man har luftiga fäljar, och inte navet är rostigt på en vecka.
Har själv köpt mycket skivor/klossar på 24.se, bara det billigaste, inga som helst problem.
Har en Suzuki Swift där naven på skivorna är svarta, och det måste vara en riktigt bra beläggning, för den är lika fin fortfarande som när bilen var ny för 4,5 år sen !!!
