I need to write in english since it's easier for me to explain ;) hoppas att det är ok med er :thumbup:
Bought a house here in Malmö couple of months ago. Now I'm starting thinking of painting it. The living room, staircase, kitchen, 2 bedrooms and a bit of the basement.
I have had dozens of painters swedish/polish/hungarian and every single painter had a different idea on what to do. The prices were quite different varying from 27000kr to 45000kr
My question is however, what do you guys/gals think on how to paint this house?
Living room: gipsskiva and then directly wallpaper glued on it
Staircase: 2 layers wallpaper on gipsskiva and then old paint on it (very ugly done)
bedrooms: Very bad wallpaper done on half torn down old wallpaper
some painters said we need to take down everything, then two layers spackel and then sand it, then paint. some said we just paint on it! some said we spackel on top of it but just take away the wallpapers that are loose and then paint. some said we need to test by spackeling on some parts. Others said since the wallpaper is glued directly on gipsskiva it's not smart to try to steam remove the wallpaper, some said spackeling or painting would cause bubbles... :o:o:o:o
I just got a crazy idea tonight to use renoveringstapeter instead on top of all surfaces! What do you guys think?
You can reply in SWEDISH<<<<:thumbup::thumbup:
I would say that it depends on what kind of surface you want. If you want it really nice you need to remove all old wallpaper. But if it is still nice you could paint straight on it :)
Sent from my HTC Desire S using Byggahus
Jag har nog provat varenda av ovanstående metod hemma, och vill du ha det absolut bästa resultatet så vill jag påstå att riva ner alla tapeter, slipa, spackla, målarväv (microlit) samt måla ger det bästa resultatet och man vet att allt är bra gjort från grunden, ingen risk att det släpper och man kan i framtiden måla över eller tapetsera utanpå med gott samvete. Detta är antagligen det dyraste alternativet om man har hanteverkare eftersom det är mycket arbetstid.
När det gäller gips vill man undvika att ånga ner tapeterna det stämmer. Men det finns andra metoder.
I de flesta fall är dock den vanligaste lösningen att riva ner lösa tapeter, slipa skarvarna och sen bredspackla, men då gäller det att det sitter ordentligt för börjar man väl spackla och det börjar bubbla sig, ja då är det bara att börja om. Jag tror alla dina förslag ovan från olika hantverkare är korrekt, för det är förutsättningarna som styr. Det enda förslag jag inte skulle gjort är "...we just paint on it"... När det gäller renoveringstapeter så fungerar det också, men det blir aldrig lika bra som att riva/slipa/spackla. På t.ex. glasfiberväv med fin struktur kan man dock få ett bra resultat med renoveringsväv, men det kräver att underlaget har en "symmetrisk" struktur, på ojämna väggar blir det aldrig bra.
