I know it is not a house question but I hope someone can help me
My battery loader in my camper (husbil) is broken and I want to buy a new one here in Sweden
I saw this one at Biltema http://www.biltema.se/sv/Bil---MC/E...r/Batteriladdare-1224-V-25-A125-A-2000037555/
Does anyone know if this one work fine in a camper ?
Thank you / tack
Thank you / tack
· Södermanlands län0
· 983 inlägg
The loader you refer to is the most powerful model Biltema has to sell. It's equipped with a maintenance loading function, as almost all electronic loaders nowadays, and will work spendidly in your camper!
Items from Biltema is normally ok. Depending on how many Ah you need, the Ctek is otherwise a premium choice.
https://www.jula.se/catalog/bil-och...llbehor/batteriladdare/batteriladdare-608065/
Thank you for helping me
I need at least 20A loading and Jula don´t have the 25A version. They have an other model which load 30A but without maintenance function
I understand that the Biltema loader is full automatic but is that correct ?
My Swedisch is not so well and the manual which I downloaded is in the Nordic lanquage but not in English
what do you mean with full automatic? It's an intelligent charger but you have to choose which charging mode you want.
Normal charge mode
Repair mode
Cold environment charge
Power source
In normal mode the charger will switch to maintenance charge automatically when the battery is fully charged
Normal charge mode
Repair mode
Power source
Yes, the one from Biltema is an "intelligent" charger.
Intelligent is the same as the automatic function on a regular charger in an camper or caravan, and supports automatic maintenance charge.
How big is the batterys you have?
If you have need for 12V 25A then it's a good buy.
I got a friend that has the same one on his boat and it works great.
I have a similair loader but when power fall off and come back I have to restart the loader again by pushing a button
I need one that restart by it self as soon as the loader is connected to the 230V outlet and it continue the last charging mode
That's something you has to ask in the store.
But in the instructions it says to connect the clamps to the battery then plug in the cord and choose mode.
It doesn't sound like it will start automatically when you plug it in, but i don't know for sure.
Later in the instructions it says connect the clamps then plug in the cord and the charging starts.
Conflicting instructions.
An CTEK isn't that much more expensive
https://www.seasea.se/el/laddare-landström/laddare-inverter/batteriladdare-25a-ctek-m300
https://www.whitworths.com.au/pdf/4107_M300_en.pdf
I only use it inside the camper, it will be fixed in the camper.
I was curious if the Biltema work the same as CTEK ? Then I buy the Biltema.
Thanks for the link 123abc, that is much cheaper then I have seen so far
· Blekinge
· 11 704 inlägg
Why do you need 20 A loading? If your battery is 55 Ah (as an example) and the charger has 8 A you can charge the battery over night. Is that too long time to wait?Nol skrev:
Whe I see the biltema you referrred to in your first post I see the thin leads and clamps. I would never run 20 A through this without feeling unsafe. 20 A can fry conndectors easily and burn your camper down.
Be careful if you use a "smart" charger and have loads active when you charge. If something draws current the charger can be confused and wait too long before going to trickle/standby charge. The battery can then be damaged. Charging with a fixed voltage (like an old stupid charger) can be safer in such cases.
