6,411 views ·
6k views
What should I use in the dog-damaged staircase?
Wait until the puppy is older and (maybe) doesn't go on the stairs again. I repaired a wooden staircase that was pretty worn out by buying a small router, then routing away parts of the stair nose. I routed enough so that I could insert a wooden strip. I bought oak, which is more durable than pine. Then I glued in the strip. On top of that, I painted the stairs in a selected color. It turned out very well.J johanlund77 said:
"Plastic padding" is not just one type of filler; there are a few different kinds. The fiberglass filler is strong and good for filling larger holes, but it's not fun to sand or try to get a smooth surface with. The "regular" filler feels a bit fragile if it were to get a kick. Ultima (I believe it is now called "superspackel") is a bit more tough and elastic and would probably work best in your case. But there might be other products that are better.
It seems like you're choosing "Plastic." Then, do as usual with window putty and mix in something that in this case the dog doesn't like. In window putty, it's usually white pepper (could work? (potassium cyanide works but might have an unpleasant side effect= DON'T choose)). Otherwise, as I mentioned early on, I would have chosen to somehow insert new real wood.G g.kraft said:
I think it's quite clear in the picture that the stair nosing is a "separate" strip, so it might be quite easy to remove the old one and replace it with a new one. If you have a router, you can create an identical profile on the strip using the old one as a template. Then the place most exposed to wear and tear is sorted.
The marks on the tread can easily be filled with any filler since the breaking forces there are not as strong.
Anecdote: When we bought our house, a strip around a door was missing. The profile of the strip no longer exists, so I bought a similar strip and then used the router in a router table to modify it. Today, no one would be able to tell which strip around the door is new, even if they were informed that one is not original. 🙂
Good luck!
Good luck!
It will be stronger if you screw in a few screws without tightening them all the way in, so the screw heads are a few mm outside. Then fill around and over the screw heads. I would use plastic padding.J johanlund77 said:
Click here to reply
