Moderator
· 57 798 posts
I have a feeling it will become a bit worse. If you can bring them together so that they become a homogeneous beam, it should be equivalent. But then we're talking about something like plyfa on both sides, and 30 - 50 nails per meter.
Grundstött
· Halland
· 28 345 posts
Member
· Blekinge
· 10 117 posts
Theoretically, two 2x4 inch beams glued and screwed together vertically become stiffer than a single 2x8 inch beam. However, it's not worth the effort. Additionally, the dimension is not sufficient for that span, as epw points out. To meet the deflection requirement, even a 45x220 with glued and screwed particle board isn't sufficient, although it's on the borderline.
Click here to reply
