S
Hi, need advice and tips before I "ruin" my fine birch plywood boards, 15mm thick
I have the following machinery:
Bosch table saw GTS 10 XC with original blade
Bosch plunge saw GKT 55 with original blade
Do I need to change the blades on the machines??
The plunge saw with the original blade (48T best for wood?) provides a very fine cut. Use the rail and place the birch plywood on a sacrificial board when sawing, the cut will be completely perfect!
The GTS 10XC with the original blade does not provide a particularly fine cut. With a custom-made zero clearance insert and a fine-toothed (sharp) blade, this saw also makes very fine cuts!
For large panels, the plunge saw is preferable, and small pieces are best cut on the table saw!
S
Thanks, I'll test the sänksågen tomorrow.
S
Made a cut with the plunge saw, best for wood, 48t. Neat and tidy cut.
A clean and precise cut on a piece of plywood, made using a plunge saw.
  • Like
falkn
Click here to reply
