16,890 views ·
17k views
Reinforce and frame old joists
Renovator
· Kalmar län
· 2 600 posts
Or place a nogging at each end of the bay (where you need to place one anyway if you are going to install floor chipboard according to instructions) and a new floor joist between these, in the middle of the bay. Or with another nogging in the middle of the bay if it's tricky with the water pipes.
Why bother with framing, chipboard, and floating floors?
If you still want a wooden floor, isn't it much easier to just install a proper wooden floor in the appropriate dimension to handle 95 cm center-to-center?
I doubt it would be more expensive.
Just to verify myself, I've done a quick Google search and calculation:
Assumed room size of about 3.3 x 5.5 m (just to get some measurement on linear meters of studs that might be needed).
Calculated at 25 linear meters of 45x120 studs at 52 kr/m (for the whole room).
Byggmax studs, chipboard, and floating wooden floor (parquet, click):
Cheapest parquet (wood, not laminate): 200 kr/m2 => approx. 400 kr/m2
Most expensive parquet (wood, not laminate): 900 kr/m2 => approx. 1100 kr/m2
Solid wood floor 34x120 (spruce) can be found for 243 kr/m2
Solid wood floor 45x145 (pine) can be found for 407 kr/m2
You're absolutely right about that. Unfortunately, too late now… If I were to do it again, I would do as you suggest. It was more cumbersome than I anticipated to fit in joists.Oldboy said:
Why bother with joisting, chipboard, and floating floors?
If you still want a wooden floor, isn't it much easier to just lay a real wooden floor in a suitable dimension to handle 95 cm center-to-center?
Just to verify myself, I have now done a quick google and calculation:
Assumed room size about 3.3 x 5.5 m (just to get some measurement on the running meter of joists that may be needed).
Calculated on 25 lm 45x120 joists at 52 kr/m, (for the entire room).
Byggmax joists, chipboard, and floating wood floor (parquet, click):
Cheapest parquet (wood, not laminate): 200 kr/m2 => about 400 kr/m2
Most expensive parquet (wood, not laminate): 900 kr/m2 => about 1100 kr/m2
Shovel out all the sawdust to begin with. You'll be surprised how much weight there is in packed sawdust. You will surely find a brick or two and such. Add joists in between and insulate for impact sound. Lay a 25 mm spruce or pine floor on top.Å Ådala said:Hello! I have torn up a slightly shaky raw plank floor and want to instead lay chipboard flooring and then a 14 mm wooden floor over it. The center-to-center distance between the joists varies from 75 to 95 cm. I need tips on how to easily arrange the joists to be able to lay down the chipboard. It's a subfloor.
The house was originally a cottage from the turn of the last century, which was renovated in 1968. That's when they nailed the joists onto the original beams to level the floor I assume.
[image]
[image]
Click here to reply
