3,391 views ·
3k views
pillar on old slab
I considered that and was a bit undecided about protecting against water from below, but chose to refrain. In hindsight, I can say that it would have been good as slip protection.Jante said:
Thanks for the input!
I had placed a slightly larger steel plate under each pillar to distribute the load.
A steel beam would also have been preferable to the glued laminated timber beam in the ceiling. A steel beam with the same load-bearing capacity has half the height.
It's 405 so I won't miss it. Especially if there is a lot of laundry hanging that obscures it.pelpet said:
It hurts like hell to hit your head on it
Click here to reply
