Planning to build interior walls with insulation in a cold garage. Possibly a future warm garage. Will unwaxed OSB absorb moisture? Also planning to paint white. I have painted on waxed OSB indoors, didn't go well. Some retailers don't even specify if the boards are waxed.
I have had regular OSB on the walls in a storage room that is not heated for many years now, see no problems with the boards.
OSB is excellent as a reinforcing board but you should of course have gypsum as the surface layer.
Diversearbetare
· Göteborg
· 11 379 posts
OSB always has wax in it. It's part of the manufacturing process. It has nothing to do with whether the surface is waxed or not. About 5% of the board is non-wood material. If I remember correctly, it's about 1% wax.U UV5 said:
Whether the paint adheres or not depends largely on whether it can form a layer that both grips in the pores and holds itself together. Rolled latex might work. Linseed oil paint probably won't work well at all, and ocher paint will wash away with the first rain (I've tested this myself).
Why not use fiber cement directly, so you get a durable surface that withstands fire, is moisture-resistant, and can be painted?
Click here to reply
