Hello
I am planning to build shelves in the storage room. 1m wide and 0.5m deep. How much weight can a shelf like that support if built from OSB without reinforcing studs except on the short sides?
Should one instead use a different type of board?
Thanks!!
Martin
Thanks!!
Martin
Member
· västra götaland
· 212 posts
Osb is terrible for most things. Including shelves. One meter is also quite long.M MartinS1980 said:
Without reinforcement, they are likely to give in quite quickly. I made them about 120 cm wide with a frame of wooden studs underneath, i.e., even along the length. I think they work perfectly up there in the attic, plastic boxes slide well on them.
https://www.byggahus.se/forum/threads/hyllplan-till-enkla-hyllor-pa-vinden.398479/
I built a simple shelf with plywood and 45mm studs. It holds well for heavy binders, etc. This one is 100cm long and 40cm deep.
Built another shelf for storage, it can handle a lot of weight. It is also built with plywood and 45mm studs.
I have some shelves in the garage made of OSB, they hold up but not in the same way. They flex a lot and have warped in just a few months.
