How do you usually do it when attaching two standing 95 studs, short side to short side? I'm going to extend a stud wall so that more insulation can fit. Right now, as I mentioned, it's just a framework. I have some theories myself, but there's surely a common method among carpenters.
So they are supposed to together form a wall with a thickness of 190 mm? The best way is to lay the inner layer crosswise to the outer one, which minimizes thermal bridges.
My plan was to place a layer of 45 crosswise outside the two 95 studs. So the wall should actually be 235mm. Is it still smartest to place them crosswise? At my brother's house, there's a vertical 195 stud from the start instead.
But if you absolutely wanted to join two standing 95-reglar, what would be the best way?
Instead of placing the studs next to each other, you should offset the studs. You frame the wall using the 95 studs on a 190mm sill, then place studs between these but at the other edge of the sill. You will then have a 190mm wall but have broken the thermal bridges through the studs. You will, of course, not be able to use 190mm insulation but will need to use 95mm in both the inner and outer frameworks.
After that, you can nail the 45s lying on these as you planned. Keep in mind that any vapor barrier should be placed between the 95 studs and the 45 studs.
Mikael_L
Before giving more tips on various ways to break the cold bridge, we should perhaps ask ourselves if the construction can manage with 45x95 in cc60 in the (load-bearing) outer walls. Is it a one or two-story building, what is the span and type of trusses, what snow zone, etc.
It is not at all impossible (I believe) that 45x95 can manage, especially if the trusses are bridged with a standing load-bearing beam under the ridge beam. But I think the question should be raised...
If you have strength requirements that require the cooperation of the two 45x95s, I don't dare to suggest any joining technique, as there may be some special forces that need to be addressed.
Otherwise, you might consider skew nailing or using nail plates (a few per stud). But since you asked about the common methods among carpenters, I really shouldn't try to answer...
Buying 195s instead, is that not worth considering? :o
It is the upper floor of a 1.5-story house in question. The construction is surely properly dimensioned for snow load, etc. My question is really about needing to extend the wall by an additional 95 + 45 to achieve the insulation thickness I need. I should have been clearer there. So my extension has nothing to do with the structural strength of the construction but is really just to provide space for more insulation and to support the plasterboard walls. Sorry! Now it might be easier to give tips.
Milkshaken
The most common way to join two studs regardless of dimension is to nail on battens on both sides of... not on the short sides but on the flats.... The battens should be at least 30 cm long, preferably 40 cm... Between 8 and 12 nails on each side of the stud... So 4-6 nails in each piece/side...
Regarding thermal bridge in this case, it's not a problem since you will be applying plastic between 95 and 45... (Outer wall) ... and then using 95 and 45 insulation..
Thanks for the response! What are the lattor usually made of? I was considering nail plates for a while, but that's probably much more expensive...
Milkshaken
22X95 or 28x95 boards are sufficient for your case..
Check my AVARTbild to see a number of slats... :)
Click on the picture to enlarge it.... We used 28X95 to join posts in 45X95.. to ceiling beams and planks of 145X 45
Click here to reply
