Hello everyone
I'm in the process of nailing up the new panel on the house and have started thinking about how I should join the flashing above the long window section.
I haven't found flashing that is long enough, so I need to join two shorter pieces.
What's the best way to do this?
- Just overlap them a bit
- Overlap and glue with something
- Cut the metal in a clever way so that the ends fit together, if so, how.
- A completely different way
Grateful for tips and tricks.
I have overlapped and then cut the front edge in a clever way so that the two parts can be pushed together. I no longer remember exactly how I cut it, but surely someone else can explain.
Same as above + a bit of silicone/latex in the joint and it will be perfect :)
Click here to reply
