You see the small crack on the edge, it came off when we removed the cover plate we had when painting. To fix this, is it possible to just use regular medium wall filler? Or do we have to use plaster?
Small crack in wall edge near window frame, caused by removing covering plate during painting. Question about using medium wall filler or plaster to fix it.
tronen said:
You see the small crack on the edge, it came loose when we removed the cover plate we had when painting. To fix this, is it possible to just use regular medium wall filler? Or must one use plaster?
[image]
Plaster is probably better.
There is something called husfix that is easier to work with and is sold in smaller packages. I would have gone for it.
Click here to reply
