15,630 views ·
16k views
Barn doors indoors, which material?
yes will do!
Bought 2 pieces of 19 mm MDF, which I will cut grooves into with a circular saw. Bought rawspont to use as a "frame" and have now cut off the tongue and groove on all pieces.
Was at Byggmax for probably 1 hour and thought through all possible combinations and which would be the cheapest/best. In the end, it was MDF and rawspont.
the dimensions of the MDF boards are h: 240, w: 59.5, thickness 1.9. all in cm. I will make two doors that are 55 cm wide and about 210 cm high. Then there will be wrought iron hinges. But pictures will come when I get started in earnest.
Click here to reply
