O
Hello,
Does anyone know what kind of ceiling is in a basement of a 1960s house? Feels like concrete but more porous. It's the same throughout the basement... water pipes running in the outer walls go up into the ceiling. I now want to cut the water pipes to instead install underfloor heating, but is it safe to saw into the ceiling to cut off the water pipes there? I've had problems with the water freezing in the outer walls...
  • Ceiling of a 1960s basement, textured surface with visible seams, light fixture, and a window in the background.
Best answer
surris
O olgavolga said:
Hi,
I'm wondering if anyone knows what type of ceiling there is in a basement of a 1960s house? It feels like concrete but more porous. It's the same throughout the basement... water pipes that run in the outer walls go up into the ceiling. Now I want to cut the water pipes to instead install underfloor heating, but is it safe to cut into the ceiling to cut off the water pipes there? I've had problems with water freezing in the outer walls...
Siporex (aerated concrete)
O
Assume then that it does not have a load-bearing structure...how thick can it be?
O
O olgavolga said:
Assume then that it does not have a load-bearing construction... how thick can it be?
Hmm, there is rebar in it and then it is indeed a load-bearing construction.
Click here to reply
