I have a LARGE area with ground elder, nettles, thistles, and other bits and pieces. Everyone says to use ground cover, but light comes through tarps and black plastic bags... gosh, so many are needed...
BUT maybe someone here in construction knows of some other black plastic, like for example used in another industry than gardening? Preferably quite thick, preferably with substantial dimensions.
I would be so terribly happy!!!
Renovator
· västra götaland
· 815 posts
a dust cloth should do....
Renovator
· västra götaland
· 815 posts
https://www.dammcenter.se/dammprodukter/dammdukar/gummiduk-firestone-19790718M MagicFingers said:
for example
Sounds expensive with dust cloth... can't you use geotextile/weed fabric?
https://www.byggmax.se/ograsduk-10-meter-green-it-p68713438#1230=91808
Or if you want to use plastic, there's for example this one:
https://gardenseedsmarket.com/tjock-konstruktionsfolie-4-x-25-m.html
Then it takes a few years before the goutweed roots die so they don't come back.
The problem with them is that they let through UV light, otherwise a good thought 😉T Testarn said:
Best answer
Click here to reply
