7,239 views ·
7k views
Hydraulic lime mortar on chimney?
Does hydraulic lime mortar need to be applied to the chimney above the roof?
So far I have used Render & Mortar Mix C to repair cracks and even out where parts of the brick have fallen off.
N
neo11
Homeowner
· Stockholm/Bromma
· 2 489 posts
neo11
Homeowner
- Stockholm/Bromma
- 2,489 posts
No, feel free to use c bruk as it is cheaper.
Why do you think you need hydraulic lime mortar?
But pure lime mortar is not wrong, weber 142, a little softer than c bruk and handles movement better.
Hydraulic is not wrong either, but it wouldn't be the first choice.
N
neo11
Homeowner
· Stockholm/Bromma
· 2 489 posts
neo11
Homeowner
- Stockholm/Bromma
- 2,489 posts
So you were planning to clean the entire chimney without painting it?
C mortar with cement is a bit grayer, hydraulic a bit yellow, regular lime mortar is probably the whitest.
But the differences are small, and you almost don't see them unless they are next to each other.
YesN neo11 said:
Then I'll do the simplest. Thanks.
If it's plastered with lime mortar, it is white and not painted. That is one reason to use hydraulic lime mortar.lllusion said:
If it's plastered with cement-containing mortar, it is gray and then painted white with limewash or silicate paint. Regarding the latter, be cautious of acrylic content in many products. So the answer is, to make it white and fake lime plaster.
Today, regular mortar is used on chimneys. But if they are to be rendered, make sure they are meshed between the two rendering layers, as it's a very exposed structure and frost damage is common. And it's super important with the construction to protect it against water. A crown in metal or cast concrete is a very good idea.lllusion said:
For older houses with heritage value, continue using lime mortar for repairs just as the original solution. Otherwise, it looks too ghetto and mixing different mortars and applying harder mortar on softer ones is not a good idea outdoors. It will come off.
I plastered with cement mortar. Is limewash painted directly on the mortar with a brush?Claes Sörmland said:
Should it dry between coats or are several coats needed at the same time to work the lime into the uneven surface?Claes Sörmland said:
Does it really stick? I've seen painted lime paint that comes off after a few years. I would rather keep the gray (cement) color than have the lime paint start to peel.
It should dry between coats so that the carbon dioxide in the air can carbonate the slaked lime. If you apply too much too quickly, it becomes more like a powder sitting on the surface and easily washes away with rain.lllusion said:
If you like the cement look, just leave it that way. Then you'll simply have a gray chimney.
Thank you!Claes Sörmland said:
I'm just wondering if there's a risk of the lime paint peeling off. White is nice but not if it starts coming loose. Does it?Claes Sörmland said:
N
neo11
Homeowner
· Stockholm/Bromma
· 2 489 posts
neo11
Homeowner
- Stockholm/Bromma
- 2,489 posts
Did you plaster with cement mortar? Which cement mortar A, B, or C?lllusion said:
If you are going to paint it, use weber lime paint 246. If the lead cap on the chimney does not leak, the chimney will stay fresh.
If it leaks, it will look bad after some years.
