Hello again knowledgeable people!
I've made some progress on the construction, so here are the next questions and thoughts. After reading and reading about different foundations, the extension now has a ventilated crawl space. The crawl space is about 60 cm high. I'm wondering if the risk of condensation on the underside is reduced if some of the heat leaks downwards. In other words, I'm thinking of some type of cement board for the floor structure, 20 cm wood fiber insulation, and wooden flooring on top. Is that completely crazy?
Grateful for all ideas, opinions, and answers!
Moisture can become a problem, so minimize the use of organic materials; fiber cement boards in the foundation pit are preferable, available for example at byggmax.
Plastic covering the bottom also keeps down the moisture from the ground. Openings in the foundation wall, especially at the corners and the middle, are good to make.
Thanks for the info!H Håbbe01 said:Moisture can become a problem, so limit organic materials; fiber cement boards in the foundation are preferable, for example, available at byggmax.
Plastic covering the bottom also reduces moisture from the ground. Making holes in the foundation wall, especially at its corners and middle, is good to do.
Click here to reply
