15,399 views ·
15k views
What size ground anchor for 95x95 posts?
I was thinking of buying a larger number of ground anchors to fasten my fence posts. Specifically 90 of them. My posts are in the dimension of 95x95mm. Byggmax has cheap ground anchors, so I was planning to buy them there. But they don't have exactly 95x95 dimensions, only 100x100. Will that work fine or should I try to find some that are 95x95?
http://www.byggmax.se/spik-och-skruv/byggbeslag/jordankare-p238245
I set my fence with 70x70 posts in Byggmax 77x77. Depending on how wet/dry the posts were, not all of them went in without whittling a bit. Once they dried in place, I inserted a carriage bolt into each one and tightened them together.
http://www.jula.se/jordankare-96x96mm-793013
Here they are.
Here they are.
Click here to reply
